05Special Posted March 11, 2006 Report Posted March 11, 2006 i am installing new carbs, can these plugs just be left unplugged? Quote
banshee350twin Posted March 11, 2006 Report Posted March 11, 2006 what wires u talking bout the once that go into the top of the carbs that hold the needles and shit on ? or are u talking bout the tores Quote
05Special Posted March 11, 2006 Author Report Posted March 11, 2006 i beleive its the tors, two gray plugs Quote
AZ Olie Posted March 12, 2006 Report Posted March 12, 2006 I already did mod's to my wiring harness, removed everything that is related to the TORS system. including all wiring in main harness for TORS system... If it matter's you should be able to unplug the connectors and the Shee will still run, what happens is that if one of the carb's slide's was to stick open when the throttle is closed it ground's out ignition and kill's the motor... Hope that this help's you out... Olie Quote
23champ Posted March 12, 2006 Report Posted March 12, 2006 you'd be better off removing all the T.O.R.S. stuff, including the little black box under the tank. When I did mine I removed everything that was related to that T.O.R.S. BS. Quote
badassbanshee479 Posted March 13, 2006 Report Posted March 13, 2006 cut those plugs out, cut the harness out that goes to the throttle, if you still have the stock clutch perch with the ebrake cut that harness offf remove the black box under the gas tank and cut the plug out of the harness. this is all tors stuff that are not needed and are real good at causeing problems when you are out riding. if you have new carbs non of this stuff is needed anyway. let me know if ya need more help. Quote
greg_banshee Posted March 13, 2006 Report Posted March 13, 2006 ya cut them T.O.R.S out of there & take that black box off to. much easier to work on after they are gone. Quote
