MDS2106 Posted February 25, 2006 Report Posted February 25, 2006 (edited) Now that I have porting done It seems like I cannot get the toomey needles dialed in.The third notch down seems to be lean and the forth notch down is to rich.I have read where a few people have had trouble with the toomey[dynojet] needles.I am at sea level running 380 main,stock pilots,two into one uni air filter,toomey t-5s, dune porting,noss head , with stock carbs. It starts and idles fine, I did a WOT plug chop last week ,looking down inside the plug it looks like I might be a little rich on the main,Its a perfect little ring at the base but it looks more brown than tan.Should I try some stock needles?Any imput is appreaciated. Anyone have a set of stock needles cheap? thank you Mark Edited February 25, 2006 by MDS2106 Quote
Big Blue Posted February 25, 2006 Report Posted February 25, 2006 I would try switching back to stock needles, My friends have always had good luck using them. Quote
Old Two-Smoke Posted February 25, 2006 Report Posted February 25, 2006 380 seems fat to me I would go up a size in your pilot jet and down one on your main. However if you truly feel you are that close, just add a small washer under the clip and you will be between the grooves.. Quote
MDS2106 Posted February 26, 2006 Author Report Posted February 26, 2006 I have some new pilots ordered,and yes I will probably lean out the main a little. Quote
wesw Posted February 26, 2006 Report Posted February 26, 2006 agree try the 27.5 pilot and 4th clip and lower the main to say 340 and do a plug chop Quote
FIRST BANSHEE Posted February 26, 2006 Report Posted February 26, 2006 Now that I have porting done It seems like I cannot get the toomey needles dialed in.The third notch down seems to be lean and the forth notch down is to rich.I have read where a few people have had trouble with the toomey[dynojet] needles.I am at sea level running 380 main,stock pilots,two into one uni air filter,toomey t-5s, dune porting,noss head , with stock carbs. It starts and idles fine, I did a WOT plug chop last week ,looking down inside the plug it looks like I might be a little rich on the main,Its a perfect little ring at the base but it looks more brown than tan.Should I try some stock needles?Any imput is appreaciated. Anyone have a set of stock needles cheap? thank you Mark 478931[/snapback] if you think the main is good and it starts and idles good, has crisp clean throttle response. don't change any think but the needle if 3rd is lean and 4th is fat try the stock needles. 340 main is to lean with a dune port, keep the 380. Quote
2003LimitedBanshee Posted February 27, 2006 Report Posted February 27, 2006 if you think the main is good and it starts and idles good, has crisp clean throttle response. don't change any think but the needle if 3rd is lean and 4th is fat try the stock needles. 340 main is to lean with a dune port, keep the 380. 478947[/snapback] I agree with that call on the main. I'm running 340 mains at sea level, 60 degrees, with the other mods in my signature on a stock port. You may be slightly fat, but I would suspect you would be lean at anything around 340. Like the others have said, I would definitely think you should bump the pilot up on, after doing that you may find that the 3rd clip is good for you. I've run the Toomey needle ever since I installed my pipes, and have had no problems getting it dialed in. Quote
digger Posted March 3, 2006 Report Posted March 3, 2006 u can buy thinner clips for the needles for finer adjustments Quote
