I need some help I am stumped. I recently put an adjustable timimg plate on my 05. I went to crank it over and no spark ! I have back tracked checked all the wires I have power to the healdights cause they start to light up when I kick it over. took my coil off checked it on my other bike it is working tons of spark. Is it possibe the cdi went out The timimg is set at zero. My brother crushed one of the stator coils (stepped on it) but like I said it still turns the lights over I wouldn't think that would have anything to do with the bike not getting spark. I have a new stator coming. Any Ideas I am leaving for the dunes Friday need help asap
Thanks
Check your pickup coil resistance. Disconect the wire harness that goes to the stator. If you have a multimeter check for resistance at these wire colors
White/red to white/green should be 94-140 ohms
If that is good check source coil esistance
Green to red 13-20 ohms
If either one of those is bad you need to replace your stator
