I remember a while back I was looking though a Dirt Wheels or Sand Sport magazine and I came across a bracket that moved the axle carrier on a stock length swingarm out two inches. It looked like a bolt on item to me but I suppose I could drop a line of weld on it to strengthen it. My question is this, I could only find the two inch extension, but I am interested in a four inch extension. Has anyone seen a four inch one or is the liability too great for the manufacturers, so they just don't even bother? I was thinking about getting some 1/4 inch flat stock and designing my own, but was also wondering if there was a reason they didn't make them already? I'm working on the motor right now and can't afford to drop another $8-900.00 on a four inch swinger. I just dont want to turtle it over every time I mash my thumb down on the throttle when the engine work is done. Thanks for the input, just an idea........... :cheers:
on my 04 i extended the stock arm 2.5 in with some 1/4 flat bar with good results the stock shock still worked good just needed a longer chain and brake line :)
I just have the stock swinger extended on mine. I want to eventually spend the bucks for a nice one but right now it works fine. There are several welders around here who do it for 150-200 but I have also seen a thread recently here on HQ where someone is doing the stockers any length for(I think) 275. Also gotta add for the brake line though :shrugani: . Otherwise the only bolt on ext. I have seen was a 4" for the Raptor
RIPPEN
I had a JTM extension on mine before I bought a longer swingarm.I think they sell for under $200.It was made out of aluminum and worked great.It also allowed alot of room for adjusting the chain.If you're not buying a swingarm,they are a great investment.I think they come in +3 and +5.Mine was the +5.They had an ad in dirtwheels at one time.
www.jaeckeltool.com
Edited by race-a-holic
This might be an old topic buy now but I just couldn't imagine paying that much to lengthin a stock swingarm ? I done mine myself with 3" cold rolled steel , and run the piss outa it . Its never givin me a problem and im still running the stock spring...you should be able to get this done for 75 or a 100 bucks at the most .. maybe its a west coast thing? :dance:
