alright im thinking about purchasing a cool head with 21 cc domes.. infact im almost positive im purchasing it.. but first i need to know what performance gains im looking to get... and where at... will it be noticeable... i know with the 21cc doems i can still run 94 octain fuel.... well guys give me some info
youll see little gains but it will cool alot better and if you go any smaller in domes youll probley have to run race gas is it the one nyuk is selling in the for sale section thats a great deal if you want one go with that one
ok i did some of my homework....
acording to noss machines diagram this is the compression ratings for 1500 elevation
19cc domes... estamated compression 163.5
20cc domes... estamated compression 152.5
21cc domes... estamated compression 141.5
stock............. estamated compression 121.5
i have also looked at trinity racing site and they said you can run up to 160psi before you need to run race gas... now my question is... if i were to get the 21cc domes (141.5 psi) and i advanced my timeing 4 degree's what would my psi be then? acording to this i think i will be bumping up my compresion 20 psi.... i think that should result in a good low end gain?
am i right?
yes it is nyuk's and im almost positive im buying it now
I just put my head on i have +4,and 20cc and couple more mods..and hell yeah you feel some gains! i feel alot more torque on the low end!!! i deff noticed the diff rite away!
460588[/snapback]
what octane are you runnin?
Re: '...and i advanced my timeing 4 degree's what would my psi be then?'
Answer: It will be the same as it would be with the spark timing retarded 4
Edited by canyncarvr
If your a gear head, you will feel a differance. Timing has no effect on static compression. I run much higher compressions in the winter but its easy to keep cool. In the summer I run less just because of the heat issue. The head helps the cooling, mine runs about 5 degrees cooler. I never worry about gas I have been running 100LL/ Nitropropane/92 mix for years. Get yourself a couple sets of domes and play. You will love the head (dont we all)
