Hey I have a arctic cat DVX 4000 and I rode it through some water and now a couple days later it starts and dies again immediatly,,If anyone has any suggestions I would appreciate it,,I was thinking that maybe some water got into one of the electric lines and is shorting
thanks Doug
not sure this is the best forum for that question most these guys have banshees here hints the name: banshee hq. if you want to get more responses do a serch on atv fourums and see what you can find im sure theres a fourum specific to artic cat's somewhere
i got a z400...and id start with the cdi probably...spray some oil down in the connecter...then check the harness...best bet is that damned harness...clean all ur connections real good brother...later...
Zuk0702
spray all connections with WD40, and check for rust..in there too, change spark plug, etc.. also
~Mark~
i just got this idea...clean your air filter!! haha it sounds obvious and stupid but many people forget..it will run for a second on the air that's in the filter and carb/intake runner already, then when it needs more air it will die like yours..good luck
~Mark~
