where can you find a cheap one do you know? and will i need any special or semi-special tools for any of this
thanks for any help
Edited by jjfizzle51
You can find the bearing kit on Ebay, or contact Jeff at Fast Racing. You can PM him here, or call, 1-785-364-5325. I used a dead blow hammer, and a socket, the same size as the bearing, to put the bearings in. Just take your time, when installing the bearings. It's pretty easy and fast. Might be a good time to replace the axle bearings and seals, if they are bad.
That's the correct kit. I use a dead blow, because it's a little more forgiving. You can use a ball pean or a claw hammer, just be very carefull, and make sure you get the bearing started straight.
that's the kit
you can use what ever hammer you got just tap it in slow using a piece of wood to hit not the bearings.
It is always a good rule of thumb to replace bearing with every new part. Keep the shee fresh and trouble free
ok thanks you guys have been a ton of help on this one. one more question is the swinger and that kit all i need and im set or am i still missing something, that i just cant take of the stock swinger
oh ya do you think this swing arm is good quality from what you see ?
thanks for any more help
looks like above average quality to me, dont do any HUGE jumps with it and you'll be fine..my only complaint would be the chrome, where i ride and how i ride it would rust rather quickly..keep that in mine, also what condition is your chain roller in?? i'm talkin about the one that goes around the left side tube on the swingarm, you might wanna replace it while it's apart with a cascade or TM designs one(i think thats the other company..i have the cascade one), also get the best chain/sprockets you can afford, even a case saver if you got the extra 25 bucks, it's good insurance
~Mark~
I f you need axle bearings or your carrier has any problems at all you my want to spend a little more and go with a round housing. It is a fantastic upgrade and I think QUICKSAND sells for around 500 carrier included. Just my.02 ~Brian~
Why not a honda style carrier? I could probably make you a killer deal on a relatively new +4 with carrier all bearings and throw in a new DID x-ring chain for the same price your gonna pay for that set-up. Cept mine has a lifetime warranty.
I BOUGHT SWINGARM FROM THAT GUY !!!!!!!!!! HE SELLS QUALITY WORK !!!! i reccomend getting the + 6 chrome with skid plate mounts ...... yes round house si better adn more $ , and overall i dont care i like to go fast and quick....... not look cool.....
