hey all im getting a port job and the guy im getting it from ( Lc racing) is saying that he recomends getting the case ported as well and also he says that its good to weld the crank. is this correct cause its an additonal $170 for this work so im just wondering if you guys also recomend this
thanks for any help
p.s. its a dune port
Yes do it!, if your crank has a couple of years on it you should also do the bearings.
