I am in the process of putting my Banshee back together and need to know what exhaust would be best?
I currently have it bored to 69.5mm with a 4mm stroker. It is fed by a pair of pwk 35mm carbs and Trinity stage 4 intakes. The exhaust I already have is a set of FMF fatty pipes and silencers.
Will the pipes I have work on my bike or do I need a set of "Big-Bore" pipes?
when I get the bike running will I see any difference between Pump gas and race fuel?
Thanks
It all depends on what you're looking for from the motor. It's not ported?
The fatty's would work, but then again the bike will run if you put stock pipes on it. It all depends on what type of riding you plan on doing. If you're in dunes, or mostly looking for top end I would look into some "big bore" pipes. Possibly shearers, CPI's, and Rockets...but you'll be waiting until Febuary for the rockets.
On the gas question. That would depend on your domes for an aftermarket head, or if your stock head is shaved. Check you're compression when you get it all together to see if you need to run race fuel. Last time I checked 160 psi was the limit for 93 octane.
I just plan on playing in some powerlines, some trails, Not really looking for top end.
I dont think it is ported, when It was rebuilt the first time We had the vito's 404 kit installed. The crankshaft went out killing my new pistons.
I was just wondering if the pipes would hold it back too much?
Thanks for the help
