Banchetta Posted December 6, 2005 Report Posted December 6, 2005 yes it probably is fading as i let the throttle back a little, it does it worse when i have a passanger with me, maybe i will go for the dynajet kit to get the bigger pilots,, any one have onfo on the V-Force 3 ? my dealer here is trying hard for me to buy it but its a bit pricey for what it looks like.. Thanks 445142[/snapback] Don't waste your money on a jet kit. Just buy the jets as you need them, way cheaper and you'll get what you want...you can get jets at magicracing.com......if your shee is fading at less throttle then your needle circuit is most likely too lean. Try raising your needles in your slides. Move the clip at the top of the needle down....you should see great gains. Quote
crank67 Posted December 6, 2005 Report Posted December 6, 2005 get 300 jets and turn air jet all the way in and back off 1 compleat turn trust me jetted lotes of bikes Quote
midnite Posted December 6, 2005 Report Posted December 6, 2005 I have pc's and they like a large pilot jet.. #30 or #32.5 will give you better low to low-mid power. Keep in mind while pilots are solely responsible for the idle to 1/8 throttle position, they never stop flowing, even at wot. Right now I'm at 360 mains, [it's 20 degrees here] and will soon try 370, and 380's. Forget the jet kit at $70, and get some jets from dinnis kirk, $6 for 2. Quote
