MATTNEY Posted November 24, 2005 Report Posted November 24, 2005 1995 Banshee rebuilt carbs with 290's and 4th position on the needle. FMF SST pipes and fiber reeds. Got it running but no pressure and lots of fuel out of one side? One pipe gets nice and warm but the other is cold, It throws alittle smoke but not the pressure the otherside puts out. One plug has good burn and the other looks brand new. What could it be? Quote
Wallrat Posted November 24, 2005 Report Posted November 24, 2005 Did you sync the carbs? Have you tried switching the spark plug wires to see if it stays on the same side? Is fuel pouring out the overflow vent on the carb? Quote
Banshee~ Posted November 24, 2005 Report Posted November 24, 2005 Did you sync the carbs? Have you tried switching the spark plug wires to see if it stays on the same side? Is fuel pouring out the overflow vent on the carb? 441150[/snapback] did you just rebuild the carbs? if so, was it running good before you rebuilt them? is the choke tube that runs between the carbs on? Quote
MATTNEY Posted November 24, 2005 Author Report Posted November 24, 2005 Yes I switched the wires, that didnt do it. I also switched the plugs and that didnt do it. There is fuel on the case and blowing out the exhaust on the dead side. It pushes out a little exhaust. Could some one give me some directions on sync. of the carbs? Thank You Quote
sand rocket Posted November 25, 2005 Report Posted November 25, 2005 did you just rebuild the carbs? if so, was it running good before you rebuilt them? is the choke tube that runs between the carbs on? 441156[/snapback] did you do this? Quote
Toomey Banshee Posted November 25, 2005 Report Posted November 25, 2005 Hey bud, not to be a dick but use the search function in here. Just type in "carb sync" and find the method that is best for you. Its been gone over a bizillion times. Good luck. Quote
wayfst Posted November 25, 2005 Report Posted November 25, 2005 if you have a ton of fuel in one side it won't fire. could be one carb has a stuck float. Quote
banshee tuner Posted December 4, 2005 Report Posted December 4, 2005 I just went through the same problem with mine and it was the reeds. My reeds looked fine but must have been opening to much and flooding that side. My right side plug was wet with fuel but did not apear to be firing. Switch your reed cages from one cylinder to the other and see if your problem switches cylinders. Quote
