2001Sheesmine Posted November 19, 2005 Report Posted November 19, 2005 Does anyone know how to adjust the tors so that my bike will idle. Is there a certain amount of turns on the screws that i am supposed to make? I dont know about that tors removal and idle kit stuff because the whole drilling and tapping the carbs would piss me off if I messed up. Quote
iceman Posted November 19, 2005 Report Posted November 19, 2005 turn the screw on the outside of the carb... Quote
2001Sheesmine Posted November 19, 2005 Author Report Posted November 19, 2005 Are you guys fuggin high? Spray some rustoleum that remotely matches the frame color and your done!The scratches will return. eventually get down to the metal. Spray it again. 438999[/snapback] Then what the hell are the screws on the TORS throttle thing? Quote
2001Sheesmine Posted November 19, 2005 Author Report Posted November 19, 2005 turn the screw on the outside of the carb... 439009[/snapback] * Quote
iceman Posted November 20, 2005 Report Posted November 20, 2005 Then what the hell are the screws on the TORS throttle thing? 439012[/snapback] could you take a picture of them. most people remove tors because it has killed people before. Quote
sandman121383 Posted November 21, 2005 Report Posted November 21, 2005 i believe the clymer calls to turn em all the way in then back em out like 2 1/2 or 3 turns. i think. neone confirm this ? if not pm me i'll dig my clymer out later for u man Quote
simonsays Posted November 22, 2005 Report Posted November 22, 2005 i think your about right.. then its usually about sensing it,by putting ur hands at the end of the pipes to see if air flow is equal Quote
ozosborne Posted November 22, 2005 Report Posted November 22, 2005 Are you guys fuggin high? Spray some rustoleum that remotely matches the frame color and your done! The scratches will return. eventually get down to the metal. Spray it again. Then what the hell are the screws on the TORS throttle thing? 439012[/snapback] Quote
MonoxideChild420 Posted November 22, 2005 Report Posted November 22, 2005 that screw on top of your t.o.r.s. is the slide height adjustment. it raises and lowers your slides(black tubes w/crescent outlet on back). whcih are connected the your throttle cable.. you have a little clear window on the side of your carbs. when you push the throttle you can see your slides moving up and down inside your carbs if you look thru the window. there is a silver piece that will appear in the window when your nobs are set right i think the silver thing shoud be visible at 0 throttle but then again im not shure . it might be 1/4 or 1/2 throttle just make shure you adjust them both the same once you get them equall, make sure they raise and lower at exactly the same time.... youll have to take oof your air box.. Quote
Banshee~ Posted November 22, 2005 Report Posted November 22, 2005 turn the screw on the outside of the carb... 439009[/snapback] Those are the airscrews that you are talking about. The idle adjusters are ontop of the tors box. Take the seat off and turn them 1/2 a turn at a time and wait 15-20 seconds for the settings to take place. Once you get it to idle good you have to make sure both of those screws are turned out the same on both carbs. When you have them lined up good (just by looking at them), turn off the gas, push the throttle all the way and then let go of it. You should hear both of the slides hit at the same time. Quote
2001Sheesmine Posted November 24, 2005 Author Report Posted November 24, 2005 thanks for all the replys. I will try. Quote
