2001Sheesmine
    2001 Banshee, White and Black, Pro Circuit Platinum Pipes and Silencers, K&N Power Kit, Reed spacers, White Brothers Boost bottle
2001Sheesmine's Achievements
  1. Have you done anything with the carbs recently? I thought I had some kind of ignition problem after I cleaned my carbs but it ended up being that one of the slides in my carb was stuck wide open. Try rolling your bike down a hill and kicking it in gear. If it runs fine after you do that I dont think its the carbs. It will probably be somthing in your ignition or magneto. If its bogging out in higher rpm check your carbs.
  2. thanks for all the replys. I will try.
  3. THIS IS THE TORS
  4. Then what the hell are the screws on the TORS throttle thing?
  5. I dont know what happened to all the other replys
  6. Does anyone know how to adjust the tors so that my bike will idle. Is there a certain amount of turns on the screws that i am supposed to make? I dont know about that tors removal and idle kit stuff because the whole drilling and tapping the carbs would piss me off if I messed up.
  7. I already ride with the cover off. Will I notice a difference if I take the whole box off?
  8. i couldnt find one on rmatv.
  9. I cant find anyone that just sells the plate or adaptor that hooks right to my carbs. I dont want to buy both the plate and filter since I already have a k&n. Anyone know where I can just get that piece? It doesnt have to be billit.
  10. Ok I took the cover off of my airbox and sent a screw through my k&n filter to the airbox to hold it in. Is there a kit that you can take the airbox completly off or should I just leave it how it is.
  11. Ok I took the cover off of my airbox and sent a screw through my k&n filter to the airbox to hold it in. Is there a kit that you can take the airbox completly off or should I just leave it how it is.
  12. I had a guy tell me the other day that his Honda 50 dirtbike would beat a banshee. You just have to wonder what these people have going through their head.
  13. I saw the video of the banshee beating the mustang.
