crbanshee Posted October 19, 2005 Report Posted October 19, 2005 so a long time ago i was asking if anyone had the white bros 265 watt stator..i got zero feed back on it fro the HQ so i just went and got it...what a piece of shit it turned out to be.first off you cant run 2 lights on this crap pile of a stator with out running a second channel which requires a second regulator,after its all hooked up and you have 2 channels running you can only run 110 watts of light from each channel..220 wats is alot of light on a banshee..but here is the problem. the stator is a hunk of shit and will fry your electrical system on your shee.. Quote
PUSH THE THROTTLE Posted October 19, 2005 Report Posted October 19, 2005 Atleast you may have saved somebody else from the same mistake. Ricky Stator is the only way to go. Quote
Proquad101 Posted October 19, 2005 Report Posted October 19, 2005 Atleast you may have saved somebody else from the same mistake. Ricky Stator is the only way to go. 427630[/snapback] Werd, thanks for thr info. Sorry you had to find out the hard way. Quote
