my banshee runs alright but then when it starts to get hot it boils the antifreeze in the cylinders. i think its my head gasket because it is pressurizing the cooling systemand the cap on my overflow bottle blows off. any suggestions on what it might be? and i think my water impeller is good.
Check the compression. It should indicate if the head gasket is blown.
deffinatley a head gasket!
get a new one and replace it, just went through all this couple days ago with my buddies shee, just make sure the surfaces are perfectly flat befor reassembaley any machine shop should be able to "lap" them on a plate to make sure.
