Guys...I need your help again........ :notworthy:
Does anyone know what the piston to wall clearance is on Wiseco forged alluminum pistons?
Had a pop noise comming from the bottom end...Sounded like a piston slap.
Can't find specs anywhere....H E L P ..... banghead
THE MODS:
1. NOSS Head
2. 21cc domes
3. Wiseco Forged Alluminum Log rod Pistons 0.050mm
4. 4mm stroker crank
5. 5mm Rods
6. Race Logic stage 3 porting
7. V-Force 3 reeds
8. Keihin PJ 34mm Carbs
9. No box lid
10. TORS is gone
11. Toomey T-5 exhaust
12. Ricky Stator timing plate
13. Compression check is 150 psi on both sides
14. I live at 2200 ft ASL.
15. New K&N Air filters with new outerwears
16. New BOSS Intake from Inland ATV.
17. Twist throttle
Edited by smallfry
check weiscos site, or your spec sheet that came with the pistons, you should be about 3-4 thou. piston slap usually rattles for a bit then goes away after warm up, If its a "pop" its prooly not piston slap.
do you mean 50 as in 1/2 a mm (=.020) or .050?, remember the pistons and engine are metric and the box will be labled in mm.
This is my luck guys... :cry:
Never a dull moment...Just got back from Dumont Saturday, while riding heard a slight pop coming from the bottom end, left side. As the day progressed, so did the pop, however, only made the noise at idle. Sounded like a piston slap. Pulled the motor to see if it was hurt, nope! No damage..... BUT....wanted to check the wall clearance to rule out that option out, but as my luck has it, NO Fuggin' paperwork...as usual.... :angry:
Tried to call Wiseco this morning/afternoon---NOT OPEN TODAY! :angry:
Tried Wiseco's website....NO INFO...as usual.... :angry:
The pistons are Wiseco forged Alluminum long rod bore 0.050mm part #316-0393. Sorry if there was some type of confusion. :wacko:
"Meanwhile at Dumont...The shee ripped 4 Brand new paddles down the middle"
Didn't really want to get into it's full potential with that pop coming from the bottom end.... :rotflmao:
Edited by smallfry
RBD...
Thanks for the info....
0.003 thousandths...
I really do appreciate the help :notworthy:
Just spoke to Wiseco..They will be e-mailing me the spec's that where supposed to be in the box from the beginning...I asked for the clearance and they stated it exactly what you responsed with...Thanks I really do appreciate the honesty! :cheers:
