2twin350s Posted October 1, 2005 Report Posted October 1, 2005 sounds like the top end is weak, but as a last ditch effort, check the choke transfer tube between the carbs. they fall off a lot. it is a 3 inch rubber vacumn line between the carbs joining them together.it goes just in front of the slides at the tops of the carbs.if it is missing it could be your problem. i would also check the compression. Quote
fast87 Posted October 2, 2005 Report Posted October 2, 2005 make sure you're running cheap pump gas with stock compression, race gas will not help in your case and start very hard when cold...pump gas it is for you ~Mark~ Quote
jbes3 Posted October 3, 2005 Author Report Posted October 3, 2005 make sure you're running cheap pump gas with stock compression, race gas will not help in your case and start very hard when cold...pump gas it is for you ~Mark~ 421996[/snapback] I'm running the 89 octane stuff we have at the pumps. Anything else up here has ethanol in it. I also use the Yamalube R oil for mixing. Quote
tyguy Posted November 7, 2006 Report Posted November 7, 2006 irun 110 octain and mine startes on 2-3 kicks, and i have lower compression... i love my race gas....IMO :smile: Quote
dajogejr Posted November 7, 2006 Report Posted November 7, 2006 irun 110 octain and mine startes on 2-3 kicks, and i have lower compression... i love my race gas....IMO :smile: This post is over a year old, why dig it up? I'm pretty sure if he hasn't figured out the starting problem, he's not going to by now... If you have lower compression...as in 150ish or less, you're wasting money or race fuel and actually probably hurting performance... Quote
