sycoracer911 Posted September 27, 2005 Report Posted September 27, 2005 alright got the shee running and the jetting is good... now if im running its kinda wierd... like if im running in 6th and let of for a little bit and then punch it it hessitates for a while... and then starts to rev.... what would cause this.... and even when you punch it it like hessitates and just all sluggish and then like hits and goes..... Quote
Blackmon Posted September 27, 2005 Report Posted September 27, 2005 suonds like your clutches might be slipping Quote
Bansh88 Posted September 27, 2005 Report Posted September 27, 2005 Sounds like you're feeling the powerband. Running 6th gear takes some straight up speed. Drop to 5th, then back to 6th when you feel the slug. Quote
trex banshee Posted September 27, 2005 Report Posted September 27, 2005 i will have to agree with bansh88 when you let off and it falls out of your powerband cruising in sixth you can really expect it to be right there just by puching right back in the throttle unless your rpm's are still up. Quote
bigboybanshee Posted September 27, 2005 Report Posted September 27, 2005 i will have to agree with bansh88 when you let off and it falls out of your powerband cruising in sixth you can really expect it to be right there just by puching right back in the throttle unless your rpm's are still up. 419963[/snapback] Agreed! Quote
sycoracer911 Posted September 27, 2005 Author Report Posted September 27, 2005 (edited) no like even if i drop a gear it will still do it Edited September 27, 2005 by sycoracer911 Quote
macgillivary Posted September 27, 2005 Report Posted September 27, 2005 i had a problem like that on my blaster, never did figure it out, seemed like a dead rev range in 6th, couple chops of the throttle would get you through it though Quote
sycoracer911 Posted September 28, 2005 Author Report Posted September 28, 2005 im not sure but i can feel them slipping bad now... so ima wait till rocky mountain gets some clutch's in stock and buy a set Quote
