im sure you guys have all got a clymers manual and im doing the hub and pipe thing and ive been hammering for a while now and it hasent even moved. the bearings went on me the other day and ive got every thing off the axle except the brake rotor. is there somthing else i can do to get it off?
any help is greatly appreciated!!
Time to bust out the big f'n hammer I'd say.. Might be easier as well if you take the carrier off the swingarm to get the whole thing off the bike. Should be able to get more leverage that way.
so did you get the axle out of the carrier yet? If so....then I just stood the axle on end and "HIT"(knocked the shit out of) the rotor hub with the BFH a few times till it started moving....
Edited by quad4me
no the axle is still in the carrier i got it loose but it wont come all the way out if seems the center long tube thing in there is hitting the right bearing so it wont slide all the way out.does the long tube thing have to come off of the left side? and it comes all the way out ? thanks for the replys
that fucker probably seized to your axle shaft. im sure youll end up hitting it enough to drive the bearing out with the axle and then just use some heat persuasion to get that center section off.
my bearing spacer was rusty...but not stuck to the axle. it drove out the right side bearing...then I had to pursuade the spacer to come off with some tapping. The rust came off enough to slide it off the axle. Then the bearing and hub were knocked off with the BFH.
Edited by quad4me
