banshee_slut Posted August 26, 2005 Report Posted August 26, 2005 when i come off the gate my shee is always spinning alot more than everyone elses, not sure if its my tires or what. my tires are stock with about 90% tread. Quote
Mxzdan Posted August 26, 2005 Report Posted August 26, 2005 (edited) try starting in 2nd gear and put your weight back it might help but be carefull if your banshee as a lot of power what kind of tire- oops I dint see your tire where stock Edited August 26, 2005 by Mxzdan Quote
Big Blue Posted August 26, 2005 Report Posted August 26, 2005 The stock tires are alot of your problem the are POS. Quote
stclark816 Posted August 26, 2005 Report Posted August 26, 2005 The stock tires are alot of your problem the are POS. 408369[/snapback] Quote
banshee_slut Posted August 26, 2005 Author Report Posted August 26, 2005 cool. thanks alot guys. Quote
locogato11283 Posted August 26, 2005 Report Posted August 26, 2005 get you some good aftermarket tires and thatll solve the problem...might try 2nd and see if you can pull a 2nd gear start if the tires are spinnin that bad.. Quote
PyRo_ZaCh Posted August 27, 2005 Report Posted August 27, 2005 when i got mine it came with half worn tires, forgot the name but i know they were what come stock on a 400 ex. on loose dirt/gravel/silt it would spind 1st 2nd and half way thru third, only moving maby 5 or 10 ft then finaly take off in 3rd, but with the mudsharks on now it launches great, esspecialy in the silt Quote
gatesy Posted August 31, 2005 Report Posted August 31, 2005 Just rev hard in second, then drop the clutch. When you get over the gate snap third. Work for me Quote
