will i have any problems with this bolting up to to the vforce because the reeds have that raised center and the intake is flat. anything i need to know? any help would be great thanks.
408273[/snapback]
The only difficulty would be if you have an older manifold, they have o-ring grooves in them and you would have to use a gasket with the V-Force reeds.
Other than that, no problem at all.
