i havent put the c.v on yet..
i want to get a perty close jetting befor i try to kick up just rebuilt motor..
i have fmf fattys/powercore
noss head/21cc
clamp on filtter/with bag..
.20 over
at sea level..
just a good jetting to be good to start with..
just need to start it.. and run it so i can start the plug chops and rejetting..
thanks alot..
devin
Ported Cylinders
Ported reed cages
K&N + Outerwear
Bored .40 over
Head milled .30
Plus 4 timing
Fmf fattys
Boysen reeds
Trinity 2:1 35PWK
I run 180main DEK needle second clip 48piolet. My bike seems to run leaner than most people on here but since your cylinders are not ported I would think that would get you close. Try on the third clip firsth though.
+ 4 stroker
.080 over
mild clean up port
20 cc chambers
fatties
33mm PWK on CV 2-1
175 main
52 pilot
DEG needle 3-4 groove depends
300 ft
Runs great. could go down on the pilot to 50. The jetting is going to be very close on a 35mm. Getting ready to try a 35 on this engine. Just go a little fat at first. You will be surprised how little main jet you can run. Mine runs a dark cocoa colored fire ring after some long straights. Rebel
