Yaxy Posted August 11, 2005 Report Posted August 11, 2005 (edited) I have the opportunity to purchase a new Banshee Pro-design timing plate for $40. Does anyone know the answers to the following: 1) Will the RZ coil assy bolt to the PD plate? 2) Does the RZ motor need advanced Timing (93 Octane, Ported, head cut) I have no experince with timing plates but I do run a Dynatek CDI on my current shee. I know that advancing the timing on the banshee helps quite a bit but do not know if the CDI for the RZ and Shee have the same timing curves, or if the RZ would benefit from the plate. Thanks Chris Edited August 11, 2005 by Chris Yax Quote
rzcolobanshee Posted August 11, 2005 Report Posted August 11, 2005 1. It depends....84 will not work, 85 will 2. Yes the timing is pretty close to the same as the banshee, I have a ricky stator plate advanced 4 deg Quote
Shee-Male Posted August 12, 2005 Report Posted August 12, 2005 Mod your stock one, 1mm = 1 degree timing Quote
Yaxy Posted August 12, 2005 Author Report Posted August 12, 2005 Thanks guys, What would be the differnce between the 84 and 85 model? Im assuming it would not be the cases so it must be the coil assy itself? I will also consider modifying the stock one. Chris Quote
rzcolobanshee Posted August 12, 2005 Report Posted August 12, 2005 84 has a different bolt pattern that holds the stator to the plate, you can modify the stator...but at that point you may as well modify the timing plate instead Quote
BenBB Posted August 12, 2005 Report Posted August 12, 2005 If only we could talk Dyna into makin' a CDI for the RZ... Quote
Yaxy Posted August 13, 2005 Author Report Posted August 13, 2005 Thanks guys foir all your help. For now I am going to leave it the way it is. I FINALLY got the RZ motor back together this morning and just waiting for my Rockets and will try to fire her up in November this year. Chris Quote
rzcolobanshee Posted August 14, 2005 Report Posted August 14, 2005 No prob, just don't get your hopes up for getting those rockets anytime soon lol Quote
Yaxy Posted August 15, 2005 Author Report Posted August 15, 2005 Yeah, Awating the Rockets, I am on the waiting list and I really don't need them until February when I pull my Shee motor out for rebuilding. If the Rockets are not in by February no big deal I have unitl next march until my shee motor goes back in. Chris Quote
FORMULASPEED Posted August 15, 2005 Report Posted August 15, 2005 If only we could talk Dyna into makin' a CDI for the RZ... 403956[/snapback] Check this out Ben.--> Digital programable cdi Quote
Yaxy Posted August 16, 2005 Author Report Posted August 16, 2005 (edited) Thanks for the link, that was cool. I will check that out Chris Edited August 16, 2005 by Chris Yax Quote
FORMULASPEED Posted August 16, 2005 Report Posted August 16, 2005 Thanks for the link, that was cool. I will check that outChris 405239[/snapback] Here is the website--> rd dreams Quote
