BenBB Posted August 12, 2005 Report Posted August 12, 2005 1 forum lurker to respond to the original post 6 months from now and start it all over again. 403523[/snapback] HAHAHAHA that is priceless!!! I'm gonna mark my calendar and repost in this thread LMAO! Quote
super88_banshee Posted August 12, 2005 Report Posted August 12, 2005 Ight den, you speiled" bene" rong. It should reed, "The lightbulb has bin changed". Whar the hell did yuo go to scool? 403817[/snapback] I wondered when someone would be our "spell checker" of the joke Quote
stuntmasta3o5 Posted August 14, 2005 Report Posted August 14, 2005 (edited) light bulb: electric lamp consisting of a glass bulb containing a wire filament (usually tungsten) that emits light when heated...The incandescent light bulb uses a glowing wire filament heated to white-hot by electrical resistance, to generate light (a process known as thermal radiation). The bulb is the glass enclosure which keeps the filament in a vacuum or low-pressure noble gas, or a halogen gas in the case of quartz-halogen lamps (see below). In Australia a light bulb is commonly called a light globe, most Australians don't realise that "globe" is not used in this sense outside Australia. 403862[/snapback] Correct me if I am wrong(Although I am never incorrect) but the term "Light Globe" was used back in the 1800s when a famous character, Thomas Eddison invented it. MeltIce, you need to refer back to a encyclopedia becuase your definition is incorrect . BTW, I use GE Lights which use a total of 7 volts per hour and have been calibrated to the my elevation level (about 1500 ft above sea level) for maximum performance - Been using them for abbout a year and a half and have no problems with them . My suggestion would be to change your current lightbulb and configure to your whole house watts, volts used per week. Then decide which is the best "light bulb" for you . Edited August 14, 2005 by stuntmasta3o5 Quote
TopGunnYFZ450 Posted August 14, 2005 Report Posted August 14, 2005 So hows that light bulb working for you? Give us a review on it did you use clear glass or the white glass?? Pretty good Quote
