Picture Second photo. Green frame with white/blue plastic #44. Since the picture it has new factory tank cover in late model blue and a matching gripper seat as well as shearer pipes.
The engine is a '99 model. The original frame was bent and it is now on a straight frame. I do not have the title to the new frame, but I still have the orginal and the title for it that can go with the bike if needed.
Engine:
4mm, .020" over Passion 12 port stroker. 2 races on new engine. New H129 crank with TZ bearing.
NOSS head
GRR lockup and GRR clutch saver
shift pro, modded star, dogs removed from tranny, billet shifter all for easy shifting.
Lightened/slotted flywheel
V-force reeds, aluminum intakes, 35 PWK carbs
New shearer inframe pipes
Dyna ignition
Engine may be available seperately. Email with offer.
Suspension:
+2,+1 Aarms, -1 roundhouse swingarm
AFCO shocks 150lb front springs, adjustable rear shock
Durablue sway bar
LSR adjustable axle
Braided brake lines
The only thing this bike needs is new rear tires and you are ready to race. It has made 80HP on a low reading dyno. Very fast with a good rider.
$3500
Email me at [email protected]
Edited by jinx44
Its loosing its fun. I don't like the promoter at the local track so I have been traveling to races. It was getting too expensive. I bought a mustang and am starting to play with it.
  • 8 months later...
it needs to go. Ready to race with just new rear tires. $3500. If you are interested in any parts, make an offer.
Engine $2000
Carbs $450
A-arms $300
Swingarm with roundhouse carrier $350
front shocks $250
Rear shocks $250
Dyna $100
Axle $125 kinda rusty
Any other parts let me know.
It would not take much to change this into one hell of a duner bike. The shocks, A-arms, powerful engine, etc are alll there. Swap to a longer swingarm and you are done. The roundhouse carrier is there, so just the steel swingarm is all you need.
Just a heads up this guy has no  morals what so ever I would suggest stay away before he rips you off. :bolt:
505739[/snapback]
I have not ripped anyone off on parts. Please leave personal hearsay out of this. It has nothing to do with me selling parts.
505739[/snapback]
OOOOOOOOOO, the 20 post member has spoken, moron. At least if you are going to post some shit like that, put up an explanation for the accused to explain their side against.
ooooo guy with too much time on his hands speaks up. this is just a heads up do the reseach on other sites. beware before you send money.
508045[/snapback]
Please provide links to any bad deals from other sites/forums. If not, could a mod please delete these posts from my thread so I can get some parts sold. :cheers:
If the complete bike doesn't sell this weekend, I will start pulling it apart next week. PM's have been replied to. I will start getting pictures of the parts next week also.
