I have a 03 banshee I wanted quicker throttle responce so I adjusted the air fuel mixture on both carbs and now I can't get it to start can any one give me some help . :(I put new plugs in and the choke tube is connected.I turned the scews on the right side on the bottom of the carbs and I hope I turned the right screws.Thanks for the help.
Edited by man27
it should still start regardless of where those screws are. sure you didnt undo something else? the choke crossover tube still on there? something besides those screws is keeping it from starting.
Keep kicking the crap out of it. Or turn the screws back to 1 and 1/2 turns out. If you turned them in too far, It will be lean and you'll have to kick the crap out of it even with the choke on......and give it a little gas every other kick or so.
Put plug wires back on after you changed te plugs?
I have a 03 banshee I wanted quicker throttle responce so I adjusted the air fuel mixture on both carbs and now I can't get it to start can any one give me some help . :(I put new plugs in and the choke tube is connected.I turned the scews on the right side on the bottom of the carbs and I hope I turned the right screws.Thanks for the help.I turned the screws 1and 1/2 turns and put new plugs in and I can't get it to do anything I tried to pull start it and it would run while it was moving but when I would give it gas it would die .
395528[/snapback]
