bigstink41 Posted July 10, 2005 Report Posted July 10, 2005 well, take a look of the mods that is done to my shee'. i just had fmf sst pipes and liked how they ran. i figured with all the mods that i had done that there could be a better pipe that would help my shee' run to its full potential. i have been leaning towards CPI's mostly. rocket pipes haves crossed my mind also, but i really just dont know. i was hopeing i could have some opinions of what to run. i dont want any out-of-frame stuff, and money should not be a problem for the most part. thanks for all the help. Quote
bigstink41 Posted July 10, 2005 Author Report Posted July 10, 2005 sorry, these are my mods. 01' banshee, polished, ported, cool head, bored .40 over, 2 into 1 38 mm carb, +4 swingarm, works triple rate w/ rez., lightened flywheel, boysen reeds, fmf sst pipes, geared down Quote
sredish Posted July 10, 2005 Report Posted July 10, 2005 we can't recommend anything without knowing what kind of power you want. CPI's and Rocket's are great pipes but they're not going to give you low trail-riding/woods type torque like fatties would, however both would complement mods well. you ought to try searching for : pipes, exhaust, fatties, toomeys, rocket.... etc. i could go on, but it'd take awhile. just search around and there's plenty to read. oh, and welcome to the hq. Quote
locogato11283 Posted July 10, 2005 Report Posted July 10, 2005 we can't recommend anything without knowing what kind of power you want. CPI's and Rocket's are great pipes but they're not going to give you low trail-riding/woods type torque like fatties would, however both would complement mods well. you ought to try searching for : pipes, exhaust, fatties, toomeys, rocket.... etc. i could go on, but it'd take awhile. just search around and there's plenty to read. oh, and welcome to the hq. 390813[/snapback] word...i would recommend rockets tho... Quote
bigstink41 Posted July 10, 2005 Author Report Posted July 10, 2005 rockets huh, i mostly ride at glamis and do alot of racing if that helps. i am mostly looking for the most low and mid range power for the hills Quote
sredish Posted July 10, 2005 Report Posted July 10, 2005 rockets huh, i mostly ride at glamis and do alot of racing if that helps. i am mostly looking for the most low and mid range power for the hills 390822[/snapback] then Rockets would work really well for you. CPI's would also work well, as well as Shearers. I'm really not too sure how the 2into1 38mm would work with drag pipes, but those pipes will fit what your looking for. If you want to ride and race but still have really good rideability, Toomey T5's are also very good pipes and might work better with your single carb setup. Quote
race-a-holic Posted July 10, 2005 Report Posted July 10, 2005 For mid range to top end,I'd use either shearer or cpi.These pipes are great for drag racing.The shearers I have pull very hard on topend.I think I'd go back to dual carbs.Although,I've never tried a single.They should get you up hills very quickly.Just make sure to hang on. Quote
bigstink41 Posted July 11, 2005 Author Report Posted July 11, 2005 so cpi's then is the answer im getting, i got the single carb to get rid of my crappy stock ones. i was told the throttle respnse is alot better with a single carb , and alot more reliable. is 38mm to small for a single carb, it was one of the biggest icould find. thanks for everyones help Quote
sredish Posted July 11, 2005 Report Posted July 11, 2005 so cpi's then is the answer im getting, i got the single carb to get rid of my crappy stock ones. i was told the throttle respnse is alot better with a single carb , and alot more reliable. is 38mm to small for a single carb, it was one of the biggest icould find. thanks for everyones help 390881[/snapback] i would definitely NOT go any bigger, if so, it'll create a lull and vacuum issues in the lower rpms. 38mm is plenty as most use a 35mm. That's whats on mine with ported cylinders. You should be alright with decent portwork and the 38, but I wouldn't go bigger. Quote
locogato11283 Posted July 11, 2005 Report Posted July 11, 2005 in most cases rockets are gonna have more on bottom than cpi or shearer with just as much and possibly more on top... Quote
hittintrees srh Posted July 11, 2005 Report Posted July 11, 2005 I cant offer to much in-put, but what i do know for sure is the the CPI's are "BITCHIN"!!!!!!!!!! For beeing an inframe drag pipe, there bottom end is resonable. There top is the selling point!! Let use know what you choose. Quote
bigstink41 Posted July 11, 2005 Author Report Posted July 11, 2005 i think i may go with the rocket pipes, after all. tell me what you think about the desicion...i belive they will make my banshee run and breath the best. thanks for everyones input you have helped me out alot! this was a pic of my banshee before i took off the fmf sst pipes Quote
hittintrees srh Posted July 11, 2005 Report Posted July 11, 2005 i think i may go with the rocket pipes, after all. tell me what you think about the desicion...i belive they will make my banshee run and breath the best. thanks for everyones input you have helped me out alot! this was a pic of my banshee before i took off the fmf sst pipes 391110[/snapback] Rockets? Sweeet!!!! I havent even seen them yet, but ill bet there fast. Ride hard dude Quote
trex banshee Posted July 14, 2005 Report Posted July 14, 2005 if you get rockets you won't be dissapointed by the performance it woke my shee up i didn't lose any low end (but i have t rex cylinders) and the top end is unbelievable i loved them just had a little mishap with the chrome but be fixed at the moment by the good guys at rocket pipes you won't be dissapointed. Quote
wesw Posted July 15, 2005 Report Posted July 15, 2005 i like my shearers. look at my dyno at the bottom of my sig Quote
