Sick Twin Posted June 28, 2005 Report Posted June 28, 2005 hey whats up all i got another banshee a few months back and had it out in the woods yesturday we was running around in some tight wooded trails showing the 4x4's we could anywhere they could and i poped it across this little ditch and had her parked slightly on a hill front left faceing down back right slightly up i walked a away for a few minutes then all i could small was the klotz running out of my case i didnt leave it sitting there long when i seen that but looked be runnig out around front sprocket when sittien level nothing happen so we towed it (is there a gasket right there and is it hard to change.and also is this just normal wear and tear and help would be greatly appreciated thanks in advance Quote
locogato11283 Posted June 28, 2005 Report Posted June 28, 2005 klotz running out by your sprocket? does klotz make gear oil? there shouldnt be any oil dripping out there. yes there is a seal there. can u get some pictures maybe?? sounds to me like you need to replace that seal in there which i think requires spilitting the cases. and even if it doesnt, more than likely if u have one seal bad there are others... Quote
