watkins Posted June 18, 2005 Report Posted June 18, 2005 In the process of installing new pipes + silencers on the shee.. got the pipes mounted fine, however I noticed that the new silencer came with some rubber bushings and also 2 long metal discs... are these needed to install the silencer? the stockers didnt have all this. And i looked at the instrustions and it doesnt say crap about those parts. Quote
Banshee~ Posted June 18, 2005 Report Posted June 18, 2005 I had the same problem, if you look at the rubber deals there not all the same and there made so one fits into the other. Heres what I finally came out with Quote
watkins Posted June 18, 2005 Author Report Posted June 18, 2005 So you didnt use that big metal piece that i got on mine? Dont really know what its for? THe piece that looks like a "T" but its round. Quote
baddboyy21 Posted June 19, 2005 Report Posted June 19, 2005 I didn't use the metal bushing either and the pipes line up fine. They don't leak at the joint either. Quote
watkins Posted June 19, 2005 Author Report Posted June 19, 2005 I didn't use the metal bushing either and the pipes line up fine. They don't leak at the joint either. 383234[/snapback] Perfrect Thanks. Quote
Banshee~ Posted June 19, 2005 Report Posted June 19, 2005 I didn't use the metal bushing either and the pipes line up fine. They don't leak at the joint either. 383234[/snapback] I used it, if you look you can see it next to the grab bar....fmf included it for some reason you think? Quote
