reservoirs are like a radiator and add cooling benefits to your shock oil. the rezzies have a floating piston in them that has nitrogen (typically) on one side and the shock oil on the other. as the shocks compress oil is forced into the chambers and displaces the gas. basically they add more oil and a larger surface area to beter dissipate the heat generated by friction. this heat reduction makes the oil keep is viscosity better and makes the shocks work like they should instead of just acting like springs.
