Just curious of what type of chain lube everyone uses. I've tried alot of them but I can't seem to find a really good one. They either sling off or catch dirt. What has worked well for y'all?
Belray chain saver.  you can't cut that stuff off with a knife.
373559[/snapback]
yep.
I don't use anything other than wd-40 and a rag to occasionally clean the chain. Anything else is just too messy.
373679[/snapback]
i hated dealing with the mess chain wax made, so now i just use WD-40 and it works great in sand and dirt.
I use dry graphite spray lube from napa. Sprays on and dries on contact.
Will not fling, sand can't stick. Looks / feels like teflon.
I also use WD40, if it was good enough for Dean Sundahl to use on his Baja winning Banshee, it's good enough for mine.
