I think I have my jetting close my plug is looking good tanish brown after each ride, the problem is, when I come into the mid range and try to rev through the high end my bike starts breaking up and studering. is this a jetting problem or is my ignition taking a $h1t? also when I rev 5th and 6th gear out and let off it bogs when I get back into the gas, I have to dwn shift and rev the crap out of it to get back into the power band, will bigger carbs fix this ??
Are you at WOT?
373652[/snapback]
when it brakes up yes, but when I come off the gas and let the rrrs die off alittle I have to clutch it back into the power band or I have to down shift a gear moving the needle seemed to help alittle but not that much, do I need bigger carbs to solve this??
373732[/snapback]
I would try to richen your main another size. If the carbs are tuned correctly, it shouldn't do this.
If you can't solve it with jetting check your ignition.  I just went through the same problem, turned out to be a bad spark plug boot  banghead
374012[/snapback]
I have had a problem with the little nut on top of the spark plug rattling lose but I took both of them off and lock tighted them, would this cause my problem??
where is everyone running there spark plug gap at? I pulled my plugs and checked them and they where at .045 so I moved them into .024 and it helped with the breaking up, but it is still there slightly
375921[/snapback]
Try running your plugs at .018" - .022". This can make a huge difference in top end performance in some cases.
so what gap are they suppose to be.  :confused:
376965[/snapback]
climers manual says .024 is the stock gap.
I will try moving mine in some more and see if it takes care of the problem
thanks for the help
Hell, I never gap my plugs, guess I should, but never have. I pull the BR8's out of the box and throw them in, and they've always worked perfectly... :shrugani:
