iv got a set of omf beadlock rear klaws on the back. if i dont go out and ride for a couple of days, the tires seem to deflate.
is this because the bead isnt on tight enuogh or a dodge valve?? i have checked for holes and whatnot in the tyres but i cant find any.
any ideas???
tithead.
Put the tires in water and look for bubbles - you should be able to find the leak this way
Edited by Tim C
Put about 7 or 8 lbs of pressure. soak em with a hose, and rub a little dishsoap on em all over.
Not a lot, just enough...it will bubble much more noticably than just water alone...
If you don't see it bubble up, then let a little air out, or...as much as you normall run.
Don't forget to put a little soapy water in the top and around the valve stem.
hey tit, whats a dodge vavle? but that whole air bubbles thing is a great idea if you have a big enbough tank. if you dont mix up a solution of a little dishsoap and some water in a spray bottle. then coat them mothers and look for forming bubbles. plus then you dont gotta wrestle around a big wet tire, kinda like stclark's mom. :rotflmao::rotflmao:
j/k stephen.
  • 2 weeks later...
hey tit, whats a dodge vavle?  but that whole air bubbles thing is a great idea if you have a big enbough tank.  if you dont mix up a solution of a little dishsoap and some water in a spray bottle.  then coat them mothers and look for forming bubbles.  plus then you dont gotta wrestle around a big wet tire, kinda like stclark's mom.    :rotflmao:  :rotflmao:
j/k stephen.
373500[/snapback]
:o didnt see that coming!!!! but thanks for the tyre solution :)
j/k stephen.
373500[/snapback]
looks like cole wants his teeth kicked in... :angry:
:D
