I got a 2001 banshee awith fmf silencers and no air box lid and oil is getting out from the silencers is that normal.
i mix 32/1 yamalube
Thanks
Ok thank's I was scared i though I already needid new ring's
372601[/snapback]
Oil in the exhaust is not an indicatin of bad rings in a two stroke. The oil is burned along with the fuel. Could be very rich jetting. Does it bog off idle??
yes it seem's to bog a little bit when it idle when it's cold
but when it's hot it does not bog so if i would put a set of front pipes I wont have to change my jetting is that right
Edited by Mxzdan
it as or do you just have a grimey seepage from the silencer that even if i clean it after each ride it does the same thing
yea, my bike smokes more out of the left pipe, i think becasue thats the side i choke to start it. Once its warm, they even out, and i have no problems.
