joshv5.0 Posted May 15, 2005 Report Posted May 15, 2005 is it possible to run 28mm carbs with a airbox. i need a bigger airbox boot, the stock one is much to small. does anyone think i will feel a performance loss switching from k&n pods back to a airbox w/ no lid? Quote
BdBanshee Posted May 16, 2005 Report Posted May 16, 2005 I used to run my 34mm PJ's with the airbox, so you should be able to rig up the 28's. I think you will have less power with the airbox when each setup is jetted correctly. Quote
joshv5.0 Posted May 16, 2005 Author Report Posted May 16, 2005 i guess i will go to home depot and try to rig something up damn i hate to lose power with the airbox but i just ride through to much water and mud to use the pods Quote
blazinlow Posted May 16, 2005 Report Posted May 16, 2005 i got 28 pwks i used a dremel tool and shaved a lil off the inner of the boot to the air box and used a heat guy to soffen the boot up and put it on the carb before i put it on the air box off the bike then put the carbs on and put the air box on last. i run with a air box with a k&n with a pro flow adapter with a not lid with a outerware cover on the box and it screams. my buddie got more mods and bigger carbs using pods and were about even in racing in the fields but i loose him in the woods when hes gotta go thru water and mud slow!!!!! Quote
