BANJO Posted May 13, 2005 Report Posted May 13, 2005 i was driving my shee.. when i went up this steep ass hill.. it stalled when i was trying to turn back down.. i rolled her down.. it took 4 kicks to start it.. witch is alot for my shee.. then i burned back to my truck.. it seemed alittle weak.. and didnt sound right.. when i stoped at my truck it stalled.. wouldnt kick over.. got ir homw..washed it.. then kicked for 10min to start it.. it would only run if i was reving it. i checked the plugs.. 1 is perfect the left is lean i think... the bike worked fine befor i stalled it on the hill.. its like theres no gas in it when im kicking it.. and it back fired a few times.. first time it has ever back fired.. what should i do??? what could it be.. just to lean on the left side?? peace devin Quote
locogato11283 Posted May 14, 2005 Report Posted May 14, 2005 check to see if the choke tube between the carbs is hooked up... Quote
BANJO Posted May 14, 2005 Author Report Posted May 14, 2005 ill check it soon.. what else do you think it could be??? peace devin Quote
cgamla Posted May 14, 2005 Report Posted May 14, 2005 When I bought mine it was like that which is why I got it so cheap. I had to rev the living crap out of it to get it running and if it dropped below the midrange I had to pull in the clutch and hold it wide open and pray it would start to speed up. Turned out all it was was a broken reed. That was so cool . I got like two grand off the purchase price for a twenty dollar reed. Yeah it would backfire and spit occasionally too. Quote
Iexpedite1 Posted May 14, 2005 Report Posted May 14, 2005 Sounds like a fuel issue to me too. Like maybe a float is sticking or something of the sort. Quote
