BANJO Posted May 8, 2005 Report Posted May 8, 2005 how tight should my axle bolt be??? i know your rear sproket should have a little play.. right??? or should i crank that sucker tight??? i just dont want to crank if its sapost to have some play?? peace devin Quote
jeepman380 Posted May 8, 2005 Report Posted May 8, 2005 I don't think it's spos to have any play in it at all. At least mine doesn't anyway. If if does you can put some washers behind the nut for some shims to tighten it up. Quote
BANJO Posted May 8, 2005 Author Report Posted May 8, 2005 i thought tho if it was tight as hell.. then wouldnt the torque rip it off or somthing.. but i geuss ill just crank the sucker tight peace devin Quote
quad4me Posted May 8, 2005 Report Posted May 8, 2005 what does your CLYMERS manual say? I know you own one! If not..it is the best $ you could spend on that shee right now. Quote
SICK BOY Posted May 9, 2005 Report Posted May 9, 2005 what does your CLYMERS manual say? I know you own one! If not..it is the best $ you could spend on that shee right now. 366417[/snapback] WORD Quote
98basketbanshee Posted May 11, 2005 Report Posted May 11, 2005 tighten the first nut to 40ftlbs then holding first nut go to 140ftlbs on outer then holding the outer nut back inner off to 170 tward outer nut always use lock tight red and it will still come lose (buy a lonestar axle and carrier ) when you get an extra 1400.00 ha ha myne is still stock i dont have the extra cash Quote
