adam Posted May 7, 2005 Report Posted May 7, 2005 (edited) i have a 1996 banshee it has a vito,s 404 mono cyclinder 4mm stroker crank and 35mm carbs .from mid to top end the right cyclinder mis fires can you help.could it be the cdi Edited May 7, 2005 by adam Quote
Bansheeman1121 Posted May 7, 2005 Report Posted May 7, 2005 Simple stuff would be is the choke on that side? Are there new plugs in it? Maybe your lean? My best guess tho would be its the reeds on that side what kind u runnin?? Quote
adam Posted May 7, 2005 Author Report Posted May 7, 2005 (edited) Simple stuff would be is the choke on that side? Are there new plugs in it? Maybe your lean? My best guess tho would be its the reeds on that side what kind u runnin?? 365861[/snapback] v force they are new it did the same when was stock it is all new Edited May 7, 2005 by adam Quote
superchicken Posted May 7, 2005 Report Posted May 7, 2005 (edited) some times with bigger carbs and radical set ups you can suck the bowl dry out of the right carb,because its farthest away from the petcock.thats why i got a pingle Edited May 7, 2005 by superchicken Quote
Rare Scottish Tree Badger Posted May 7, 2005 Report Posted May 7, 2005 You could elimminate plug, plug caps, and leads by swapping cylinders to see if the missfire moves to the other cylinder. If it does, then one of those three's your problem. Rare. Quote
