adam
Everything posted by adam
  1. it is like it bogs with no power would you go bigger or smaller on the main
  2. whats up you guys i have a 96 banshee it has a vitos 404 mono cylinder 68mm a 4mm storke crank long rod a set of 35mm carbs ,dyna fs ,rocket pipes .what it is .it run good to a little over half throttle .then it is like it just trys to shut off.if you let out a little and it comes back if you can help please let me know i am putting nos on it and i don't wont to melt it down thank evey body
  3. whats up i just need to know how to convert a set of 35mm keihin carbs and how to mix the alcohol with the oil thank you all
  4. v force they are new it did the same when was stock it is all new
  5. i have a 1996 banshee it has a vito,s 404 mono cyclinder 4mm stroker crank and 35mm carbs .from mid to top end the right cyclinder mis fires can you help.could it be the cdi
