i dont like doing them with the banshee because of the pipes, i bet its not even possible with rocket pipes. i used to do them sometimes, just gotta not be scared to go over the bars. i would slam on the front brakes in second gear and get it up pretty high.
It all depends on what you're trying to do it on. I was getting 'em pretty high with my t-5's in some grass/dirt. I really wouldn't wanna try with some big ass rockets. I sucked at 'em until I learned how to use my hips. I slam my hips into the bars when I grab my brakes and the back end comes right up. (I would be careful trying this on pavement)
im not a professional or anything at this but i can do them and the trick is to bring it up slow but this is usually only possible on pavement. You lean forward a lot and tap the front brake, then tap it again harder and then once more even harder and hold down (this is what i do) and if you do it correctly, then the bike should come up just fast enough that you have control, not violently or anything. As long as you dont come up to fast and get enough momentum, then even if you do go to far, the front bumber will hit and stop you from flipping, because the banshee has a low center of gravity. take note this is on a stock banshee with a stock bumber and any modifications to the banshee's dimensions will affect the outcome.
Darren
ya that was when i first started trying was half a foot. i can do em like that tapping the breaks good on my bike but on my quad its way diff. i thought it would be pretty similar. ill see what i can do with a lil more practice. im going riding all day tomorrow so it shall bring some endos im sure
just put your legs over the handle bar and hit the brake your feet will catch you if you go to far, practice makes perfect i can roll it about 10 to 15 feet like this at about 11 oclock
365571[/snapback]
man thats just too much for me
