markzx7
markzx7's Achievements
  1. if you still got it let me know im interested
  2. thanks for the help you all
  3. that is one diffrence in them they run overides i didnt want to go with the over ride cause we drag in feild and just mess around alot and i was told they only take a few tenths off of your et when i redone it put in new shift forks modified shift star and a shift pro. it shifts like a dream
  4. the motor wont pull the 17
  5. he didnt give me any specs but pretty much every 4mm motor he does runs in the 6s in the 1/8 last i heard he ports fredy sanfords cylinders in nc and they have some pretty impressive stuff
  6. ill give you a liitle history on this i got a local builder to build my 4mm motor when i got it back it never really ran that good, my stock port stock stroke cpi piped bike almost beat it. my setup was 4mm longrod 795 pistons .20 over timing plate advanced %6 cpi in frame 34mmpjs drag ported 14/41 gearing hemi head with cut domes. best times in the 1/8 mile was 8.8s tryed to gear higher but it wouldnt pull it. talked to the builder and he said i needed diffrent carbs and pipes. he said i needed 35.5ftz mikunis and out frame drag pipes. well i got the carbs and grr suicide pipes and try it and still no help. well i took it to anther biulder to look it over and come to find out that the port was for a stock stroke crank. so i sold the cylinders and got another set and had them ported for a 4 mill and went .80 over with blaster pistons. well here is my problem the bike runs better it will leave out in second where it wouldnt think of it before but still i wont runn less than an 8.8 in the 1/8 ive tryed everthing jetting is on tried diffrent timing tried diffrent gearing dont know what else to try. im just wondering if it is in the porting again is there any way to compare my specs with any others so i can rule this out, or any suggestions of things to try
  7. just put your legs over the handle bar and hit the brake your feet will catch you if you go to far, practice makes perfect i can roll it about 10 to 15 feet like this at about 11 oclock
  8. why was the blondes belly button soar? her boyfreind is blonde to
  9. whats the diffrence between a blonde and a washing machine? washing machine doesnt fallow you around for two weeks after you drop your load in it
  10. i got a 95 that wasnt running for $600 had some wires hooked up wrong ran great after i fixed that i got a 99 for $1000 that was a theft recovery it was beat all to shit but ran great then i got a 2000 model with a long story i bought a wrecked gsxr 750 for $1200 spent $800 fixing it ended up trading it for the 2000 banshee from the same guy i got the bike from. sold the 2000 to my brother for $3000 and he put nos cpis dyna ignition etc. blew a crank seal and sold it back to me for $1500 and i am always looking for good deals
  11. whats the worst thing about eating a veggitable? picking her and putting her in the wheel chair when you are done
  12. 4 mill and a cub
  13. wheres the best place "cheapest" to get the pro wedges and the 4snows at
  14. please recomend the best tire for hard pack dirt drags 250'. i currently have ohtsus 501s but they will not hook until i hit third leaving out in second. my motor is a 4 mill drag port and i run 14 41 gearing. any help will be greatly appreiciated.
