what fuel to oil ratios are u guys runnin, cuz the guy i bout the quad off didnt tell me an what ive been runnin looks like its a little rich?
iv bin runnin 160ml to 5 litres of petrol
363510[/snapback]
Are you in Europe? ... I ask 'cos in the Uk we talk about ml (mililitres) and petrol.
If so, your 160ml per 5 litres is a ratio of 31.25 : 1
What kind of oil are you using? That usually determines what ratio you should be using.
I use Silkolene Pro 2 (Full Synthetic Ester) at a ratio of 33:1 (150ml per 5 Litres of fuel).
Rare.
im running putoline mx5 2stroke oil
363859[/snapback]
According to their website ( http://www.putoline.com/eng/start.html ), MX5 is a Synthetic/ SAE 40 which they say to mix at 2 - 4 % which will be between 100ml and 200ml per 5 litres. ... 2% is 50:1 and 4% is 25:1
Putoline is European and therefore you might be better to use Quad Heaven in the UK to see if anyone's using it in their 'Shee here for an idea of what ratio to run.
I use their light gear oil for the trans. (SAE 75).
Where abouts in Scotland are you?
Rare.
