03bluebansh Posted April 30, 2005 Report Posted April 30, 2005 i was going to put my adjustable stator plate on today and i can not get the nut broke loose on the flywheel, the engine dont have enough compression to hol it, how do i do it??? Quote
BigRed350x Posted April 30, 2005 Report Posted April 30, 2005 (edited) That's why they make a FLYWHEEL PULLER tool. duh An impact gun works great as well. Edited April 30, 2005 by BigRed350x Quote
05bansh Posted April 30, 2005 Report Posted April 30, 2005 The flywheel puller is a must! Also an impact wrench makes it twice as easy. Quote
23champ Posted April 30, 2005 Report Posted April 30, 2005 A flywheel puller will do no good unless the flywheel nut is off first. use an impact wrench to get the nut off the flywheel. Then use a flywheel puller, if you don't have one... go get one. Your local dealer will most likely have one for around $20. Mine is acually for a CR 250 but it works on the banshees also (just incase your yamaha dealer doesn't have one). Quote
locogato11283 Posted April 30, 2005 Report Posted April 30, 2005 flywheel puller. paid 11 bucks for mine at the dealership. it wokrs for the cr500, cr250 and banshee that i know of. like 23champ said, you need to get that nut off with a 17mm impact first. you can prolly get a buddy to hold the flywheel and that should be enough to get it spun off. Quote
brock_fuzzy_69 Posted May 1, 2005 Report Posted May 1, 2005 as the shop i go to says.................that flywheel puller works for 90% of the dirtbikes and ATV's in the world Quote
RNBRAD Posted May 1, 2005 Report Posted May 1, 2005 If you don't have an impact, use a strap wrench to hold the flywheel in place to loosten the initial nut. Quote
