hey guys besides my bearing retainer, another problem was with my a-arms hitting my pipes. does anyone else have this problem because it suxx!! messed up both of the pipes and im afraid to get new ones because i dun wanna mess them up too. does ne one have ne solutions
362613[/snapback]
I have a good inch between the two on mine. Are you sure your not talking about the tie rods? something is not right take some pictures and post them.
ive never heard of that hapepnin, pics would be great!
362725[/snapback]
Never even a hint of such a thing. Something is bent somewhere.
Without seein pics it's difficult to say, but I'll go ahead and throw in my .02 Some of the original pipes for the Shee were designed around the J-arm frame. They stretch way forward and if installed on a later A-arm frame, clearance with the top bolt could be an issue. (Because the A-arm is longer and reaches further back) I've seen this happen before and could be what's up. :shrugani:
Anyhow, post some pics when you get 'em. I'm sure everyone on here will be more then willing to lend you some advice. :cheers:
DJ
try switching the pipes. put the left to the right and right to the left. see if that helps :confused:
363314[/snapback]
better yet, turn them upsidedown and point the stingers staight up!
