littletroll Posted April 29, 2005 Report Posted April 29, 2005 I just bought a noss head and was wanting to know if there is any difference between the noss domes or the prodesign domes, also do you have to have the seal washers and acorn nuts that comes with new ones or will the stock studs be all i need thanks Quote
NEVER SATISFIED Posted April 29, 2005 Report Posted April 29, 2005 i believe there is no difference in domes.. but a noss head has better cooling, as for the hardware you will need them... Quote
locogato11283 Posted April 29, 2005 Report Posted April 29, 2005 noss head uses stock studs. put the copper washer on then the acorn nut. PD heads use aftermarket studs with ugly factory nuts on top. noss head looks and functions better i think. domes are the same. Quote
bigboybanshee Posted April 29, 2005 Report Posted April 29, 2005 noss head uses stock studs. put the copper washer on then the acorn nut. PD heads use aftermarket studs with ugly factory nuts on top. noss head looks and functions better i think. domes are the same. 362127[/snapback] Exactly Quote
littletroll Posted April 29, 2005 Author Report Posted April 29, 2005 Thanks i appreciate the info Quote
