I just bought a noss head and was wanting to know if there is any difference between the noss domes or the prodesign domes, also do you have to have the seal washers and acorn nuts that comes with new ones or will the stock studs be all i need thanks
noss head uses stock studs. put the copper washer on then the acorn nut. PD heads use aftermarket studs with ugly factory nuts on top. noss head looks and functions better i think. domes are the same.
362127[/snapback]
Exactly :cheers:
