87banshee388 Posted April 24, 2005 Report Posted April 24, 2005 Does anyone know an easy way to adjust the shift linkage behind the clucth? Quote
RBD Posted April 24, 2005 Report Posted April 24, 2005 Get a shop manual, it will give you a step by step instructions and have pictures too. Quote
FIRST BANSHEE Posted April 25, 2005 Report Posted April 25, 2005 tip your bike on its side and remove the clutch cover and adjust. simple as that, about 30 min. Quote
87banshee388 Posted April 25, 2005 Author Report Posted April 25, 2005 Hey thank. I tried to adjust it in aguast but you still sometimes have to play with the shifter a little bit to shift. Quote
ledofthezep Posted April 25, 2005 Report Posted April 25, 2005 When you adjust it...you want to have the arrow on the arm where the cable connects on top of the motor pointing at the arrow on the case itself, with about 1/8", maybe hair over that play so you don't weld the clutch ball & rod. Quote
