I just tore down my shee today and I had one melted piston. Im thinking of haveing it ported.If so would I end up needing bigger carbs?. Or is there anything else I should upgrade due to the increase in power.As of now my mods are
paul turner powerhead 22cc domes
paul turner midrange pipes
duncan pyramid reeds
k-n pro flow filter
ajustable timing plate +4 and Im still running the stock carbs.Also need some advice on what pistons to get,a good strong durable set thanks
ive heard the wiseco make pretty good pistons, but dont actually know my self :confused:
k-n pro flow filter
356709[/snapback]
wiseco pistons, and stock carbs will perform everything your pipes will put out.
wiseco makes good pistons. you can get the stock carbs bored out to 28 so it will perform better. as for porting, get eric gorr's mo betta everywhere port, its real cheap at 200 bucks, and will perform real good, just ask stclark and locogato. only thing i would change is gearing to get the full use out of your mods.
