Absentxx Posted April 6, 2005 Report Posted April 6, 2005 So my banshee wont go into any gears, when i start it it will just sit there and idle anyone have any suggestions what it might be before i tear it apart? Quote
fixitrod Posted April 6, 2005 Report Posted April 6, 2005 Can you give some more specifics. Did you happen to just put a clutch in it or anything. That's kind of what happens when the pressure plate isn't lined up with the inner hub, but we need more specifics. Did it just quit. Have you been working on it. Did you jam on the shifter really hard and it quit. Does the clutch handle pull right. Quote
Absentxx Posted April 6, 2005 Author Report Posted April 6, 2005 Can you give some more specifics. Did you happen to just put a clutch in it or anything. That's kind of what happens when the pressure plate isn't lined up with the inner hub, but we need more specifics. Did it just quit. Have you been working on it. Did you jam on the shifter really hard and it quit. Does the clutch handle pull right. 350728[/snapback] Ya sorry about that just kinda frustrated , no i was at the dunes and it was runnign fine, next thing i know my friend comes walking back and says my shee broke down, so we pull it to camp... thinking that its in neutral cause its coasting fine.. he tells me that he was just ridding it then he started coasting and came to a stop when he was in gear reving it up it wouldnt go.. the clutch lever works fine and everything.. i also changed the gear saver two rides ago Quote
fixitrod Posted April 6, 2005 Report Posted April 6, 2005 If the clutch handle seems really soft he may have welded the ball to the pushrod and it's holding the clutch open. Does the shifter feel right or does it not click. Quote
Absentxx Posted April 6, 2005 Author Report Posted April 6, 2005 The lever feels fine but the shifter is pretty soft it will go up and down pretty good.. and its like its always in neutral but it was in a gear when he stopped, supposively. Quote
fixitrod Posted April 6, 2005 Report Posted April 6, 2005 (edited) I'd start by pulling the clutch cover... Hopfully you find the adjuster tightened itself up or something simple. I hope it's not internal or you'll have to split the cases. Maybe the shift shaft claws aren't engaging the shift star. Good luck. If there is anymore info post it. I'm sure someone will chime in. Oh, and welcome to bhq. Edited April 6, 2005 by fixitrod Quote
Absentxx Posted April 6, 2005 Author Report Posted April 6, 2005 hehe ran out to dink with it some more, thanks i will keep you up to date on how its going, gotta wait for paycheck before i get to involved Quote
ssanddemon Posted April 7, 2005 Report Posted April 7, 2005 (edited) Personally, I'd make my buddy get involved! Your type of problem is why I loan the toys out less and less as I get older. Good luck, man! Edited April 7, 2005 by ssanddemon Quote
chevyboy51 Posted April 7, 2005 Report Posted April 7, 2005 I would check the clutch i have seen them so smoked that they would seem like the quad was in neutral when it was in grear Quote
MILO Posted April 7, 2005 Report Posted April 7, 2005 Personally, I'd make my buddy get involved! Your type of problem is why I loan the toys out less and less as I get older. Good luck, man! 350842[/snapback] yeah, you hate to tell a friend no, but damn that kind of shit gets old! 90% of the time when something of mine got broken, it was someone else that did it. so i put an end to the lending deal long ago. those situations can turn a good friendship sour too. Quote
frocashmoney24 Posted April 7, 2005 Report Posted April 7, 2005 im with rod, pop off the clutch cover and see what you got, maybe the peice that rides on the shift star popped so far off its not grabbing anything, not even the pegs, or maybe the shift star came undone? def check teh clutch side first. Quote
PUSH THE THROTTLE Posted April 9, 2005 Report Posted April 9, 2005 Open it up and take a look. I've had my clutch boss come unscrewed once, clutch fell off in my hand once I had the cover off. Quote
