I've made my banshee into a monster. But, I looking to go faster,HHMMMM imagine that..I not sure what I'm looking to do next. I've ported & polished, Noss Head w/ 17cc domes, CPI Inframes, Trinity Single Carb w/ K&N, V-Force Reeds, Hot Rod 5mm L/R Crank and Lightening Ignition. Any suggestions? Alcohol? Big Bore? Cheetahs? I'm looking for some info..Help..
346159[/snapback]
If you're serious about power, dump the single carb setup. I have one & it's not the hot set-up for serious horsepower. :bolt:
346166[/snapback]
Very true.
346166[/snapback]
Very true.
346167[/snapback]
i agree. that was thing first that came to mind when i read your post before i read the previous replies. i have a 2into1 with a 35mm keihin and it will be gone after the summer. you'll step it up a notch when you put dual 33mm or 35mm carbs on there. but after that you'll have step up to alcohol, nitrous, cheetah cub cylinders, or the big daddy cheetahs, which you'll need the dual carbs for anyway.
Thanks Guys..I've benn thinking about going back to the 2 carb setup for awhile..Who do u think has the best carb intakes??
346330[/snapback]
Well, I hate my Pro Flos. The grommets on the boost bottle leak (sand into my motor)! Fixed now, but a real POS design.
346330[/snapback]
Well i just got a set of boss intakes. I havent got to use them yet but they look good and very well made.
